2005 Chevy Monte Carlo WIPER MOTOR
2005 CHEVROLET MONTE CARLO
JPM656
Computer problem
2005 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
WHEN I TURN MY WIPERS OFF THEY NOW STOP AT THE TOP INSTEAD OF THE BOTTOM
Feb 24, 2010 at 7:58 AM
BASSTECH
  • 236 POSTS
Check and see if the wiper nuts have come loose at the bottom of the arms. If they are, adjust the wipers down, then retighten.
If they are not loose you could have a problem within the wiper motor park switch, and may have to replace the wiper motor.
Feb 26, 2010 at 7:23 AM
JPM656
i fixed the problem turns out there is a metal tab that stops the cam and kicks the wipers back and the tab was bent down. i bent it back up and am back in buisness. thanks for the reply
Mar 2, 2010 at 10:05 PM
