I have a 2005 Monte Carlo with a sunroof. For the past few weeks, the carpet is soaked, there is some water on the driver's seat, and the headliner is wet on the driver's side. I have sealed the roof seams where they go under the windshield seal/gasket with silicone. The most likely suspect is the sunroof gasket/rubber but it appears to be in good shape. I have read a few posts about a windshield water deflector and clogged sunroof drain tubes but I'm not sure about these. I need some input from someone who has expierenced and how they fixed it. Thanks for your help.
Jan 21, 2010 at 7:58 PM
