2005 Chevy Monte Carlo Traction Control
2005 CHEVROLET MONTE CARLO
ADS777
Tires and Wheels problem
2005 Chevy Monte Carlo 6 cyl Automatic 54000 miles
My traction control feature engages when I am just pulling out of a driveway or taking off from a parking spot and only going under 5miles/hr. The traction control light on the dash comes on AND the tires feel as if they are spinning but almost unable to grab hold of the street properly. I have to release the gas pedal for it to stop.
Please help?????????
Jul 21, 2009 at 5:13 PM
BUSTEDNBROKEN
  • 8 POSTS
Sounds like you have a wheel speed sensor going bad.
It is reading that you have a wheel locking up and so kicks on the Trac control. Over 5mph it is probably getting a reading and so it only does it at lower speeds. The sensor is not bad enough to throw a ABS fault code(and kick on the ABS light), but bad enough to cause issues...
Jul 25, 2009 at 7:17 PM
