2002 Chevy Monte Carlo Electrical
40,500 MILES • 6 CYL • 2WD • AUTOMATIC
JERRYFILLER
My horn began honking by itself and now the lights flicker as well. Is this an electrical problem?
Is there a simplesolution?
Mar 29, 2008 at 4:20 AM
MERLIN2021
  • 17,250 POSTS
Open the underhood relay center, pull the horn relay out, see what happens, I thinks it's either the relay, or the horn button.
Mar 29, 2008 at 4:57 AM
MERLIN2021
  • 17,250 POSTS
Reply to your PM: Unplug the horn use a test light and check for a short between the relay and the horn...
Mar 29, 2008 at 12:20 PM
JERRYFILLER
First, the horn honked on its own, then the lights flickered and then a clicking sound comes from the all the areas where there are fuses. Now all of these things happen simultaneously unless I disconnect the battery. Local service station couldn't find the problem. Anyone have any ideas?
May 2, 2008 at 1:15 AM
MERLIN2021
  • 17,250 POSTS
What I recommend is a trip to Chevy, have it scanned for Body codes, the BCM might be loosin it!
May 2, 2008 at 8:34 AM
