I have no heat on either the passanger or driver side.
I noticed that the coolant temp was remaining on the low side I suspected that the thermostat was stuck open I replaced this and am now back up to normal operating temps and can see the thermostat cycle but I still have no heat. Both hoses from the heater core are hot. It was recomended that i may have air trapped so I spent an hour trying to get the air out I started to get some heat now. I wonder if i may still have trapped air I am not sure how to reliably bleed out the air properly and when to use the bleed screw by the thermostat. I also verified that the blend doors function properly.
Oct 21, 2009 at 12:04 PM
