Our car has the dual temperature zones and we are currently not getting any heat to the driver side. This seem to be a pretty common problem affecting the temp door actuator (most likely) control panel (possibly) or wiring/vacuum tubes (least likely). Based on you experience what part should I buy first? I would like to have them on hand so I don't have to rip the dash apart twice. Also, can you give me a good description on how to locate/replace the temp door actuator? Chilton or haynes don't say much about it Thanks!
SPONSORED LINKS
Tuesday, September 29th, 2009 AT 10:10 AM
