2005 Chevy Monte Carlo
80,000 MILES • 6 CYL • FWD • AUTOMATIC
RICK000777
My a/c only works on half of the car, the passenger side, not the driver side. What could be the problem and how do I fix it if possible. Thanks
Oct 28, 2009 at 12:32 PM
  • 110,246 POSTS
Chances are there is a vacuum leak. The vents are actuated by vacuum. Therefore, I recommend that you check for leaks under the dask. With the engine running, you may hear a hissing sound where it is leaking.
Let me know what you find.
Nov 18, 2009 at 1:42 AM
