2005 Chevy Monte Carlo
32,000 MILES • 6 CYL • FWD • AUTOMATIC
VKMRAK
I have no heat on either the passanger or driver side.
I noticed that the coolant temp was remaining on the low side I suspected that the thermostat was stuck open I replaced this and am now back up to normal operating temps and can see the thermostat cycle but I still have no heat. Both hoses from the heater core are hot. It was recomended that i may have air trapped so I spent an hour trying to get the air out I started to get some heat now. I wonder if i may still have trapped air I am not sure how to reliably bleed out the air properly and when to use the bleed screw by the thermostat. I also verified that the blend doors function properly.
Oct 21, 2009 at 12:04 PM
RENAUDTN
  • 636 POSTS
First make sure your coolant is at proper level in your radiator and in your overflow tank. This is done with the engine cold. Add some if necessary. Then put your car on ramps/jack stands. The purpose is to have the radiator neck as the highest point in your cooling system. This helps to get rid of the air.
Then take the radiator cap off, and open the bleed screws. Squeeze the upper radiator hose to get the air out of it. Turn your car on and let it warm up. When coolant starts pouring out of the radiator neck, put the cap back on; when coolant comes out of the bleed screws in a continuous stream, shut them (leave them open as long as it’s only dripping). It can take several attempts before you get rid of all the air.
Oct 22, 2009 at 7:55 AM
