2004 Chevy Monte Carlo water under the dash
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIEROB
The question I have is that I have a 2004 Monte Carlo and as I be driving I can hear water moving around in dash. Could you give some ideals what can be causing this?
May 17, 2010 at 8:01 AM
HMAC300
  • 48,601 POSTS
your a/c drain is probably plugged up. crawl under th car on teh pasenger side and you'll see a hose pointing down. try to get something to stick inside it to clean it out. you'll probably get wet.
May 17, 2010 at 10:48 AM
