2004 Chevy Monte Carlo rumbling sound follows vehicle speed
70,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGRED1966
hi,lately the sound is like an outboard motor that follows the vehicle speed,the trac off light was on this morning but it went out,the owners manual says that could be related to a brake issue involving the traction control system,i assume the abs system controls traction as well,the brakes still work fine but the noise has remained,it has 4 wheel disc if that helps....thanks in advance for any ideas mick
Dec 6, 2008 at 6:36 AM
MIKE H R
  • 3,094 POSTS
I don't think that the outboard motor sound has anything to do with the traction control, With car running check for the location of the noise. If you hear a rattling sound under the car check to see if it comes from the catalic converter.
Dec 22, 2008 at 2:27 AM
