2004 Chevy Monte Carlo Condensation
53,000 MILES • 6 CYL • FWD • AUTOMATIC
JHOUDE67
Condensation dropping on passenger side floor instead of outside.
Jun 21, 2009 at 3:21 AM
  • 110,248 POSTS
Is this from the AC? If so, the drain tube is most likely plugged. It is a black rubber tube. Check under the hood on the firewall or under the vehicle to locate it. After you find it, simply move it around or take a wire and try to snake out the clog.
Jun 21, 2009 at 12:59 PM
