2004 Chevy Monte Carlo Brake Lights
2004 CHEVROLET MONTE CARLO
RECONN1968
Electrical problem
2004 Chevy Monte Carlo 6 cyl
Right turn Signal works on top light. Left turn signal works on bottom light. Both brake lights work. Is there an easy fix...
Feb 17, 2010 at 2:58 AM
JDL
  • 16,098 POSTS
Hi, your saying the high-mount brake lite flashes like turn signal? I'd check the ground circuit at tail lamp assembly, black wire.You could probably try a redundant ground, for testing, see if it helps anything?
Feb 17, 2010 at 3:24 AM
RECONN1968
[quote:3a80d0833d="jdl123"]Hi, your saying the high-mount brake lite flashes like turn signal? I'd check the ground circuit at tail lamp assembly, black wire.You could probably try a redundant ground, for testing, see if it helps anything?[/quote:3a80d0833d]
Yes, but the light stays off untill the turn signal is turned on. Is this idicative of what you have seen before?
Feb 17, 2010 at 3:33 AM
RECONN1968
[quote:8fe9e44bf2="Reconn1968"][quote:8fe9e44bf2="jdl123"]Hi, your saying the high-mount brake lite flashes like turn signal? I'd check the ground circuit at tail lamp assembly, black wire.You could probably try a redundant ground, for testing, see if it helps anything?[/quote:8fe9e44bf2]
Yes, but the light stays off untill the turn signal is turned on. Is this idicative of what you have seen before?[/quote:8fe9e44bf2]
Also the Lower Mount does not flash.
Feb 17, 2010 at 3:40 AM
JDL
  • 16,098 POSTS
hi, I haven't seen this exact issue before. All I can do is track the circuits. Yellow wire is voltage for turn, white wire is voltage for brake, black is ground, the other one is tail lights.
https://images.2carpros.com/forum/automotive_pictures/170934_left_turn_assembly_1.jpg
Feb 17, 2010 at 4:15 AM
