2004 Chevy Monte Carlo ALL DASH GAUGES ARE NOT WORKING
2004 CHEVROLET MONTE CARLO
139,000 MILES • 6 CYL • FWD • AUTOMATIC
KATEEDID34
The gauges on my 2004 Monte Carlo SS are not working. They began to fail @ approx 85,000 miles starting with the engine oil light. One by one, they all began to fail with the speedo being the last to go. Is this caused by a broken multifunction switch in the steering column? The dummy lights (check engine, low tire, change oil) are still okay. The dash is not digital.
May 25, 2010 at 2:53 PM
FACTORYJACK
  • 4,159 POSTS
The multifunction switch would have no effect on gauges. The best way to isolate if you have a gauge cluster issue would be to perform a gauge sweep test that requires a scan tool that can access the IPC. This will be a straight forward test, if the gauges don't move when commanded, it is internal IPC fault. I know a dealer scan tool can achieve this, not sure in the aftermarket world.
May 27, 2010 at 4:51 PM
