2003 Chevy Monte Carlo Which way should I go with my MAF se
138,010 MILES • 6 CYL • FWD • AUTOMATIC
SEAL0716
  • 15 POSTS
Awhile back my car was stalling for no reason constantly. After much trial and error I finally unplugged the MAF sensor. It never stalled again. No clue why just started running perfect afterwards. However of course now the check engine light is on and I believe I could be getting better performance if I had the sensor in. So my question is should I buy a new stock MAF sensor and replace it and hopefully it doesnt stall, or should I replace it with those performances MAFs since I would like to get better performance? Also are those aftermarket sensors direct bolt on including the plug?
Aug 22, 2009 at 3:27 PM
BMRFIXIT
  • 19,053 POSTS
Finding the problem was the task
replacing the sensor should be an easy job
personal opinion on high performance MAF sensor is a waist of money
an after market should do the job just fine
good luck
Aug 23, 2009 at 12:43 AM
