2003 Chevy Monte Carlo spark plugs and wires
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEMAS25
How do i put my wires in the right place for the monte carlo from shortest to longest?
Feb 27, 2009 at 4:17 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:56e42d9fc3="mikemas25"]Engine Mechanical problem
2003 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic 119000 miles
How do i put my wires in the right place for the monte carlo from shortest to longest?[/quote:56e42d9fc3]
Hi Mike,
If you haven't started yet , then change one plug at a time and take the plug wire off and measure side by side the new wires and pick out nearest match.
If you have already started and pulled all plugs and or wires off you will need a firing order for that vehicle and will have to kinda guess the correct lengths for each wire....
Look up your firing order at the following address...
autorepair.about.com/od/enginefiringorders1/Engine_Firing_Orders.htm
Feb 27, 2009 at 4:29 AM
