2003 Chevy Monte Carlo Heater/ A/C
63,000 MILES • 6 CYL • FWD • AUTOMATIC
RICK MEAGHER
Heater blows good air from a/c ducks on right side (cool) not hot , no air from left side Good air flow from heater and defroster but cool not real hot.
anti-freeze full , a/c ? started to blow a little cool at end of summer/ not real cold.
Why would air flow be good from heater/defroster outlets but not a/c ducks
Nov 20, 2009 at 12:37 PM
  • 110,248 POSTS
It sounds like you have a vacuum leak. The vent doors that direct the air in the direction you want are run by vacuum. Start by checking for vacuum leaks under the dash. IF the engine is running, you may actually hear a hissing sound.
Let me know what you find.
Dec 5, 2009 at 11:57 AM
