2003 Chevy Monte Carlo heated seats
52,000 MILES • 6 CYL • FWD • AUTOMATIC
BOWEAVE4945
the drivers side heated seat does not get hot . the light comes on to let you know that it is on but it does not get hot
Dec 12, 2008 at 1:53 PM
MIKE H R
  • 3,094 POSTS
check the connections unde the seat, to make sure they are getting a good connection. you can also check to see if you are getting power to it by using a tester. Disconnect the plug under the seat and check to see if you have power to it. if the other seat gets hot then you have power from the fuses.
Dec 22, 2008 at 2:20 AM
