2003 Chevy Monte Carlo Coolant smell
2003 CHEVROLET MONTE CARLO
200,418 MILES • 6 CYL • FWD • AUTOMATIC
GIANTS
Why after running the engine do I smell coolant outside the car, yet there are no coolant leaks?
Aug 12, 2009 at 10:49 AM
  • 31,937 POSTS
Hi there,
You may have a small coolant leak that is burning off before it hits the ground, this is normally the case when you have a strong coolant smell, get a cooling system pressure test done first as this will locate any small external leaks, start here.
mark (mhpautos)
Aug 12, 2009 at 10:09 PM
