2003 Chevy Monte Carlo Changing The Rear Spark Plugs
106,853 MILES • 6 CYL • FWD • AUTOMATIC
LOUISWQ
Can you tell me if there are any special tools needed to change the rear plugs. Also and information in the best way to change them. They seem a bit hard to get to. What steps do I need to do to change them. Your help is greatly appreciated.
Thanks,
Lou
Jan 20, 2010 at 3:25 AM
ERNEST CLARK
  • 1,730 POSTS
There's no special tools required. Just a little elbow grease.
Some mechanics choose to remove a motor mount and engine torque arm and jack the back side of the motor a few inches to make it a little easier. But it isn't necessary, so long as you have a good spark plug socket with a swivel. The magnetic kind would be best (with a few different lengths of extensions), since it's so easy to drop the spark plug.
If there's any components on the firewall that seem to be in your way, just remove them.
Hopes this helps. Good luck wrenching!
Jan 26, 2010 at 1:46 AM
