2003 Chevy Monte Carlo car does not accellorate properly
70,000 MILES • 6 CYL • FWD • AUTOMATIC
MOTFIAMIKE
i scanned the computer and i received code po404 which was something do with improper egr something i replaced the egr valve and i have the same problem there is also a whistling sound when i try to accellorate. any thoughts on what my problem might be?
Sep 5, 2008 at 5:17 AM
MOTFIAMIKE
it had a severe lack of power won't climb hills or shift properly it seems
Sep 5, 2008 at 5:24 AM
BMRFIXIT
  • 19,053 POSTS
check exhaust system
do a back pressure test on the exhaust system checking the catalytic converter flows
check for vacuum leaks
and MAF sensor
Sep 5, 2008 at 6:16 AM
