2003 Chevy Monte Carlo
82,652 MILES • 6 CYL • FWD • AUTOMATIC
TRUCKINMAN
My car falls flat on its face when I try to accelerate. It almost fells like it is starving for fuel but it is reading 50 psi at idle and over 60 psi while driving. If I acclerate slowly it picks up fine but if I mash the pedal it feels ilke it loses 3 cylinders. I just completed a complete tune-up and there is no change in its perfromance. What could it be?
Feb 9, 2008 at 4:25 AM
M8TRIX01
  • 36 POSTS
It could be a coil pack going bad or it could be a Mas Air Flow Sensor, or a Throtle position sensor. Do you have a check engine light or anything?
Feb 9, 2008 at 5:00 AM
2CARPRO JACK
  • 11,533 POSTS
Try loosening the exhaust befoe the cat converter and driving it. Loud, but if the cat is bad it will run ok
Feb 10, 2008 at 12:02 AM
