2002 Chevy Monte Carlo Why to the lights blink on/off after
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
KEVIN ELLIS
Recently while driving my car the voltmeter in the dash started bouncing from high voltage to low voltage causing the battery light to come on intermittantly. I got the car home and turned it off. The front lights as well as the backup lights would click on and off and does so for hours at a time. At times it will start and run like nothing is happening and runs fine. I took it to a auto parts stop and asked them to check the alternator and battery and they said they were fine. The car starts regularly but the voltmeter gage and lights continue to do what they've been doing. My thougt it there is some kind of short somewhere that is cuasing this.
Jan 21, 2009 at 8:45 AM
  • 110,248 POSTS
Hi:
This sounds like there is a problem with the factory alarm system. You should contact a dealer to have them check it. They will have to proper test equipment to check and diagnose the problem.
Jan 27, 2009 at 5:34 AM
