2002 Chevy Monte Carlo Vibration
2002 CHEVROLET MONTE CARLO
QUIXOTIC706
Steering problem
2002 Chevy Monte Carlo Engine Size unknown Front Wheel Drive Automatic 103300 miles
There's vibration when I drive it at low and high speeds. I took it to a shop and they gave me a printout of a diagnosis. I replaced a hub bearing, axle shaft, and a main motor mount. My car still shakes. I tried driving slow (5mph) and I wobbled a little side to side. I'm going to try replacing the transmission mount and torque struts today but I don't think that will fix the vibration problem.
Feb 3, 2008 at 7:58 AM
MERLIN2021
  • 17,250 POSTS
Check the tires! If it wobbles like that at slow speeds rotate the tire and see if it improves. If the vibration seems to shift to the back or middle of the car, replace the tires. could be a shifted steel belt...
Feb 3, 2008 at 8:03 AM
