2002 Chevy Monte Carlo power steering
171,000 MILES • 6 CYL • FWD • AUTOMATIC
CAMIPHONE17
I recently purchased a 2002 monte carlo SS without power steering assuming that i could save some money by fixing it myself.
After getting the car on a lift and looking at everything everything looks fine. There is no leaks in the power steering pump and the rack & pinion look ok.
So is there a way i can test to see which one needs to be replaced??
any suggestions would be very appreciated.
Mar 8, 2009 at 4:14 AM
  • 110,246 POSTS
Chances are the pump is bad. If the rack was, it would work at times. Also, does it make any noise?
May 13, 2009 at 1:36 PM
