2002 Chevy Monte Carlo my car shakes
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
KYLE002
My car shakes when breaking at high speeds. And hops as it comes to a stop on service roads. I just replaced both from rotors 8 months ago and its shaking again...should I just replace the beak pads or do the rotors once again?
Jan 24, 2010 at 8:48 AM
SCOTTY DEE
  • 592 POSTS
Verify the inner and outer tie rods are tight. Remove and check runout on all 4 rotors, if out of spec. replace rotors and brake pads as a pair. Ensure that there is no rust on the mounting surfaces behind the brake rotors.
Jan 26, 2010 at 10:54 AM
