2002 Chevy Monte Carlo fuel injection
2002 CHEVROLET MONTE CARLO
75,000 MILES • 6 CYL • FWD • AUTOMATIC
SHERWIND
If the fuel injector o rings were bad would you smell fuel and if the injectors were bad the car should have a FI code correct? I was told to replace the o rings and the injectors
Jan 22, 2009 at 7:57 AM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Can you see any leakage? Fuel lines, anywhere? There are injector codes,but, only for circuit integrity. I don't believe there is a code for a leaking injector.
You could get a code for system too rich or lean. If the problem was bad enough, you might get a misfire code. Codes don't always set when they should. Can you chek the vac line for the pressure regulator, to see if it is dry?
Jan 22, 2009 at 1:48 PM
