the car hesitate to come up to speed?
65,000 MILES • 6 CYL • FWD • AUTOMATIC
PERCYPRINGLE2
i own a 2002 monte carlo that i drove everyday, now the car hesitate to come up to speed when i first take off from a light. people told me i needed to change my fuel filter and get a tune up so i got that done and it still didn't run right. then the man at auto zone said i need to change my transmission filter, so i did that and it still didn't work. So now there are people telling me to change my fuel pump and i really don't think it is my fuel pump. now i'm here to ask for your opinion on what could be the problem.
Dec 16, 2007 at 1:37 AM
DENNYP
  • 1,824 POSTS
You should have your fuel pressure checked to see if it drops off during accelleration.If it does, then change your fuel pump.
Dec 16, 2007 at 5:56 AM
  • 55,684 POSTS
I agree with DENNYP, this sounds like a weak fuel pump issue, here is a guide to help you test the fuel pressure which you can rent the kit from the auto parts store for cheap or free.
Key On Engine Off 52-59 psi
This guided can help as well
https://www.2carpros.com/articles/engine-hesitates
Here is how to do the test and change the fuel pump out in case it fails the test. You are lucky because the fuel pump has a trap door. Check out the images (below). Please let us know what happens.
Oct 30, 2024 at 11:24 AM
