2001 Chevy Monte Carlo Stops what seems to be no reason
151,349 MILES • 6 CYL • FWD • AUTOMATIC
SVOSS11
I have a 2001 Chevy Monte Carlo SS that has stopped on me twice in three weeks for what seems to be no reason. Both times I had just filled my gas tank up at two different BP gas stations. After it stops it will start, but then stops as if it's not getting enough gas or not idled high enough. I took it to the dealership after the first time, which they found nothing and it seemed to be fine up until today. They supposely checked everything; even the voltage of the fuel pump. Do you have any suggestions?
Mar 29, 2009 at 12:44 PM
  • 110,248 POSTS
If it happens when you fill the tank, check the fuel filter to make sure it isn't getting plugged.
May 13, 2009 at 1:17 PM
