Yes my check engine light is on, I am getting a few warnings on occasion deriving from this problem. I am getting "service traction" and ABS turns off, fuel indicator goes to zero, check oil & it has oil, temp. Goes up and it has plenty antifreeze. As you can see, WOW! I will have the temp sensor checked. Is there something which could be directly affecting all this sensors?
SPONSORED LINKS
Tuesday, February 16th, 2010 AT 11:16 AM
