2001 Chevy Monte Carlo Service Engine Soon Light
JOHNNYJK
  • 2001 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 84,000 MILES
I have a service engine soon light that is on and checked for codes and no codes and don't really know if it is a service for oil. I changed the oil and nothing in the books let you know why the light is on. The check engine lamp is off. Is there a oil procedure you have to go through to shut the light off?
Friday, January 1st, 2010 AT 6:23 PM
  • 109,885 POSTS
Try this:
With the engine off, place the key in the run position. Press the gas pedal to the floor 3 times and wait. If it is an oil reset light, it should begin to flash or you may hear a ding. Once that happens, turn the key off and then start the car. The light should be reset.
Let me know if this helps.
Monday, February 15th, 2010 AT 1:46 PM
