2001 Chevy Monte Carlo running bad
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
HENIG8
  • 5 POSTS
The car feels like it is running out of gas going uphill.
The engine misses and has no power. Replaced 1 coil, spark plugs and wires and oxygen sensor. Anybody else having this problem. If so, what is the solution.
Thank You,
Aug 10, 2009 at 7:36 AM
JDL
  • 16,098 POSTS
Hello, if this is a 4 speed overdrive, does it make any difference if you climb the hill in third?
If you think it is a fuel issue, use a gage and check fuel pressure?
Aug 10, 2009 at 8:07 AM
HENIG8
  • 5 POSTS
Fuel pressure is good and new fuel filter put in. Still running bad going up hills.
[quote:4e7bc87ab1="jdl123"]Hello, if this is a 4 speed overdrive, does it make any difference if you climb the hill in third?
If you think it is a fuel issue, use a gage and check fuel pressure?[/quote:4e7bc87ab1]
Aug 11, 2009 at 5:17 AM
