2001 Chevy Monte Carlo parking lights
BEHELDSCURRY
Electrical problem
2001 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
parking lights willl not shute off after car is off.
If the parking lights stay on after the car is turned off which causes car battery to run down on a 2001 monte carlo how do you fix this?
Feb 3, 2009 at 12:21 PM
  • 110,248 POSTS
Hi:
It could be a short allowing power to go to the lights or a bad headlight switch. Start by having the switch checked. If it is good, you will need to trace wiring looking for a short.
Feb 5, 2009 at 8:13 AM
