2001 Chevy Monte Carlo No Sound, At All
JOHNLEW7
Electrical problem
2001 Chevy Monte Carlo 6 cyl Front Wheel Drive 210000 miles
I had a computer replaced last year, and now I have lost my sound, ie: Stereo system as well as door chime and the control button "beeps." Once and a while for no good reason the stereo will just come on, and as suddenly as it comes on, it goes off. I suspect a wire connection somewhere, but I don't know where to look.
Sep 23, 2008 at 1:27 AM
RHALL77
  • 3,361 POSTS
check the back of the radio and fuse box. do you have a after market alarm or remote start on it
Sep 25, 2008 at 7:58 AM
JOHNLEW7
There is an after market remote starter installed.
[quote:3ed1c1098a="rhall77"]check the back of the radio and fuse box. do you have a after market alarm or remote start on it[/quote:3ed1c1098a]
Sep 26, 2008 at 1:05 AM
RHALL77
  • 3,361 POSTS
check your connections there right at the accessory wire. does your HVAC work ok
Sep 26, 2008 at 1:11 AM
JOHNLEW7
The HVAC seems to work fine, except for an occaisional fan switch issue. It shuts off sometimes, but if I turn the switch back and forth it will come back on.
[quote:851872617d="rhall77"]check your connections there right at the accessory wire. does your HVAC work ok[/quote:851872617d]
Sep 26, 2008 at 6:55 AM
