2001 Chevy Monte Carlo Mass Air Flow
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MRSPARROW
I had replaced the MAF(Mass Air Flow sensor) on engine, and the same code comes up repeatedly. The car acts like it has a fuel problem. You have an answer?
Mar 16, 2009 at 3:54 AM
RHALL77
  • 3,361 POSTS
check the terminal tension on the connector and make sure it is tight. try disconnecting the sensor and drive it and see if you have power. if you dont look at the fuel system. do you know what % it is reading when you snap the throttle?
Mar 18, 2009 at 3:00 AM
