2001 Chevy Monte Carlo intermittent clutch operation
106,000 MILES • 6 CYL • 4WD • AUTOMATIC
DESERTSTARS
When operating, A/C blows super cold air. But, clutch intermittently disengages even though t'stat is not satisfied.
Guages indicate proper charge and suction and presssure readings are normal.
Something is causing the clutch to disengage within moments of engagement. Clutch then is again pulled in and cycle repeats. The interval between is usually a matter of seconds. Sometimes, the clutch doesn't engage at all. Sometimes it remains engaged for many minutes. I suspect a control of some type but it could be for other reasons also. Perhaps mechanical.
Any ideas?
Apr 26, 2008 at 7:33 AM
DENNYP
  • 1,824 POSTS
check the pressure readings on a scan tool. You might have a bad pressure sensor.
Apr 29, 2008 at 2:47 PM
