2001 Chevy Monte Carlo
148,000 MILES • 6 CYL • FWD • AUTOMATIC
CTOTHEB35
My Monte Carlo is hesitating 10 to 15 minutes after I start to drive when I step on the gas I thought it was my oil because I didn't change it until 4000 miles after i was suppose to but that didnt fix the problem i need help
May 17, 2010 at 4:38 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 22, 2010 at 4:08 PM
