2001 Chevy Monte Carlo
EZZYBABE
Engine Cooling problem
2001 Chevy Monte Carlo V8 Two Wheel Drive Automatic
what should i do if my car messages me nd says it has hot engine coolent temp?
Aug 23, 2009 at 4:09 PM
  • 31,937 POSTS
Hi there,
When the engine has cooled, check the coolant level and top up if low, if it is low you will have to get the system pressure tested for external leaks, if the level is ok, have the thermostat replaced and check cooling fans are working, start here.
mark (mhpautos)
Aug 23, 2009 at 6:00 PM
