2000 Chevy Monte Carlo will not acclerate
168,000 MILES • 6 CYL • FWD • AUTOMATIC
THE DAKE
I replaced the elect fuel pump in the tank . i also bleed the gas line at the engine .I have plenty of gas at the engine , but the engine will not acclerate and idles rough. I also checked to make sure the charging system is working propely.
Aug 16, 2010 at 2:24 AM
  • 75,988 POSTS
If it's not slipping-see below:
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Start here inspect and test all the items below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 16, 2010 at 9:49 AM
