2000 Chevy Monte Carlo removal of power window switch
2000 CHEVROLET MONTE CARLO
180,000 MILES • 6 CYL • FWD • AUTOMATIC
TULEY
I have tried to remove the power window switch mounting in the door panel to no avail. I'm afraid that if I pry any harder I will damage the door panel. I have removed one screw.
May 27, 2008 at 12:05 AM
DENNYP
  • 1,824 POSTS
Front Side Door Window Switch Replacement (Monte Carlo)
Removal Procedure
Remove the front door trim panel. Refer to Front Side Door Trim Panel Replacement .
Remove the armrest pull cup. Refer to Armrest Pull Cup Replacement .
Remove the window switch by pressing the thumb tab retainers outward and remove the switch from the pull handle.
May 28, 2008 at 3:36 PM
