2000 Chevy Monte Carlo oilpan replacement
TILO1968
Engine Performance problem
2000 Chevy Monte Carlo Front Wheel Drive 111000 miles
what is the cost to replace an oilpan that has a small leak? And who would you recommend? Can one of you guys fix it? It is hard to find someone I trust that will repair my car and not overcharge me.
Oct 9, 2009 at 7:56 AM
  • 110,248 POSTS
Where is it leaking from? And I'm sorry, but you are most likely a thousand miles away from me.
As far as the cost, the job calls for 4.6 hours labor. Times that by the labor rate in your area. As far as a new oil pan, the original equipment one will be in the area of 190.00 and the gasket around 70.00.
NOTE: I'm sure you could get an oil pan from a salvage yard for under 50.00 and an aftermarket gasket kit for about 30.00 from a parts store.
Oct 26, 2009 at 3:12 PM
