2000 Chevy Monte Carlo Filler Valve Acts Clogged
2000 CHEVROLET MONTE CARLO
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
JORDAN JACKSON
When fueling, the filler valve will appear full and not allow fuel entry to the tank. If I disconnect the hose on the purge solenoid assembly, located in wheel well next to filler valve, the fuel flows freely to the tank. What gives ??? Thanks for your support.
Feb 14, 2008 at 5:44 AM
DENNYP
  • 1,824 POSTS
The hose is for the vent valve. The vent valve is probably clogged or stuck closed.
Feb 18, 2008 at 12:29 PM
