2000 Chevy Monte Carlo engine trouble
117,000 MILES • 6 CYL • FWD • AUTOMATIC
BRYANH87
i have a 2000 monte carlo ss 3.8liter v6 with about 117,000 miles on it, it seems like it has no power anymore it still starts fine stays running and drives but when i try to accelerate from like 60mph to 70mph it bogs down and hesitates, i will have the pedal just about floored and still nothing, i replaced all spark plugs and wires and it has a rebuilt transmisson and put a new mass air flow sensor in it so thats all working properly, i was thinking maybe bad fuel pump? i dont know i just dont want to replace somthing that is not broken, also my gas guage doesnt read right, it goes up and down no matter how much gas i put in it the guage will bounce up and down so i never know how much gas i have
Aug 11, 2009 at 2:11 AM
  • 110,246 POSTS
I would start by checking the catylatic converter to see if it is plugged. That will cause a power loss. As far as the fuel gauge, it is most likely a bad rheostat on the float in the fuel tank.
After driving let the engine run and check the catylatic converter. See if it is glowing red hot. IF it is, it's plugged. If it isn't, I would still have it checked for back pressure.
Aug 14, 2009 at 6:08 AM
BRYANH87
well now today i started it up and all my guages were out nothing worked even the radio and the a/c didnt work ither, i drove home shut it off started it back up and everything worked fine agian, i do have a stripped battery but i dont know if that could be the cause of it
Aug 16, 2009 at 11:00 AM
  • 110,246 POSTS
Did anything work when the gauges were out, or did it start just the same? If so, I would recommend having the BCM checked.
Aug 16, 2009 at 12:54 PM
BRYANH87
i started it up and pulled out of the drive way and then noticed nothing worked, but it started fine and it drove fine but no lights no radio no gauges no speedometer no nothing, i finished running my errands without shutting the car off then went home and shut it off then started it right back up and everything was fine it was wierd
Aug 18, 2009 at 12:18 PM
