2000 Chevy Monte Carlo car will not start
OSBORNE76
  • 2000 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 165,000 MILES
When I turn the key it sounds like the starter is engaging but it does nothing. I had the battery checked and it is good. What can I do.
Monday, January 25th, 2010 AT 7:16 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Monday, January 25th, 2010 AT 9:11 PM
