2000 Chevy Monte Carlo battery connection
PATFITZ24
Electrical problem
2000 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
My car wont start.When I pop the hood I move the positive wire around then I get power again.THen I can get It to start.Do you think nI need to replace the whole pos. wire or can I fix the problem some other way?
Feb 6, 2009 at 1:02 AM
JDL
  • 16,098 POSTS
If you can move the whole connection, it isn't tight enough. You might take the cable loose and wirebrush the connection on the cable and battery. On a side post battery, you can get a new stud at the parts store.
As far as the cable, if you can see corrosion up under the insulation, get a new cable.
Feb 6, 2009 at 1:12 AM
