MY SYSTEM TRCTION LIGHT AN TRACTION CONTROL LIGHT COME ON HOW DO I REPAIR THIS PROBLEM I KNOW SOMETHING IS WRONG BECAUSE IT GRINDS AND THE BRAKE PEDAL PULSES
Monday, December 29th, 2008 AT 1:18 PM
MECHANIC
Hi:
The grinding is most likely worn brake pads that are cutting into the steel rotors and need replaced. As far as the pulsation, the rotors need cut or replaced. Anymore, they have become so cheap to purchase new, it's not worth cutting.
Let me know if this helps. Also, make sure the brake fluid is full.
