2000 Chevy Monte Carlo
SANEA
MY SYSTEM TRCTION LIGHT AN TRACTION CONTROL LIGHT COME ON HOW DO I REPAIR THIS PROBLEM I KNOW SOMETHING IS WRONG BECAUSE IT GRINDS AND THE BRAKE PEDAL PULSES
Dec 29, 2008 at 5:18 AM
  • 110,246 POSTS
Hi:
The grinding is most likely worn brake pads that are cutting into the steel rotors and need replaced. As far as the pulsation, the rotors need cut or replaced. Anymore, they have become so cheap to purchase new, it's not worth cutting.
Let me know if this helps. Also, make sure the brake fluid is full.
Jan 4, 2009 at 6:33 AM
