My car will not run for longer than 10 min or so. If you try to restart it after it dies the exhaust is rich and it will not hold an idle. If you let it cool down it does the same thing again. I recently replaced my plugs and wires and coil packs. What else could it be.? I've been told several things. One it could be my temperature sensor? Two it could be my cam shaft sensor? Without a engine light on I can not diagnois it. Please help it is starting to get cold out.
Nov 20, 2008 at 4:27 AM
