Security light (left side dash) on with 2 starts. Then,, after driving to store, won't start again - power disappears on crank, no solenoid click. 2 hrs later, starts as if nothing happened. Drives for 3 days, 10+ starts.
Right after short drive and shutdown, turned ignition to on to close driver window but no lights, is completely dark. After never hearing the door open chime, before, I now hear it. Left overnight, now I hear a clicking noise in the right side of the trunk, No start, no power, still getting a strong door open chime. Obviously a wiring issue. Dealer says it is the cylinder lock having "high resistance" causing system to not read the key (has a resistor) which seems fairly ridiculous.
Dec 3, 2008 at 8:26 PM
