1999 Chevy Monte Carlo Runs hot.
18,000 MILES • 6 CYL • FWD • AUTOMATIC
DIRTYGERTIE
  • 9 POSTS
I have changed the thermostat already, and have used radiator stop leak, my car still is running hot. I can turn on the heat and it will cool down some what.
Aug 31, 2008 at 12:19 PM
RHALL77
  • 3,361 POSTS
is your cooling fans working ok, did you bleed the cooling system out enough, did you hook up a scan tool to see what the temp is reading on the computer, you may need just a sensor. is the water pump working properly
Sep 3, 2008 at 10:52 AM
