1999 Chevy Monte Carlo overheating/empty resevoir
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
JBELETZ
my car overheated this last weekend and i filled it up with coolant and water, when i park it at nite and check it in the morning it is empty agian, but i dont see a leak anywhere? any ideas?
Aug 10, 2009 at 7:41 AM
  • 110,248 POSTS
It may have drawn the coolant into the radiator if it was low. Keep refilling it to see if it eventually stops. Also, check the engine oil to make sure it isn't a creamy white indicating coolant mixing into the oil.
Let me know what you find.
Aug 14, 2009 at 6:10 AM
